I am not going to run it in like the book says, baby it till 1000k's, as I don't want a slow motor. How have you run yours in. I am thinking of following the run in as I have done with my jappers, taking into consideration the lower rev's on harley's.
On my Jappers I followed the run in stated below and always had good strong motors. Redline 15,500 rpm.
I always bring rev's up nice and easy, not full throttle,
50 - 100k's I took it easy.
200 - 300k's I would run 5-6 grand touching 6-8 grand
300 - 500k's I would use mid range rev's 6-8 grand and bring it up to 10 grand.
500 - 700k's I would run 8-10 grand and push it up to redline.
ride it hard till 1000k's, bike is run in.
Usually do it over 2 -3 days. I did most of this running in on country roads, using different gears to stick to the speed limits of course.
Hey rans I will let you know some numbers in about 3 weeks for stage 4. Am expecting mid 100s even with good set of 2 into 1s. Book is full of shit 115 is highly unlikely. Dv8 your right them pipes won't do you any favours
Well, picked bike up today and did about 60k's home. I follwed the motoman run in procedure. Basically used 2nd or 3rd gear and ran 2500-3000 up to 4000rpm and back down first few runs, then went from 3000-5000 rpm next 5 or 6 runs. took it easy till freeway and then sat on 3000rpm and bove, passing using 3/4 throttle till 5000rpm. varying speed and rpm the whole way.
At first i didn't feel the difference and was not impressed with the upgrade. ( had 211 cams, intake and exhaust) to stage 4 103 kit with SE260 cams. I have found the upgrades to be deceiving, as i thought the kit would have been hard core, but found the power to be very user friendly and going much faster than it feels. Previously with 211 cams, doing 100k's in 5th and excerlating would be sluggish, dropped to 4th and be ok, now with new kit in 5th, hit the throttle and you are doing 140 before you know it. It now passes with ease and think when this kit has been run in and dyno'ed, It will be a pretty good sit up.
Will test run against a mates who's bike is the same as I had, but his bike was always a little faster, as he run his in really hard. It will be interesting.
hey dv8 are you sure the cam is a 260 because thats what they ran in the older kits and i know the latest stage 4s now run a 259E with a few other slight changes to change the dynamics
no worries let us know how ya go
