Online: beaglebasher
Adding 4" to a Fat Boy
  • rix181
    rix181
    I own a FLSTFB 2011 Fatboy Lo I wan't to fit 4" pullback risers for the handle bars and I was woundering if there is anought slack in switching wires clutch cables brake lines ect and is it a DIY.Any info wellcome.
    Cheers Rick
  • simmac18
    simmac18
    You should be fine I could do it with my 03 Fatboy, when I put a set of Deuluxe risers on, since changed the bars so don't have them on any more, but from standard went on easy. All reports that I have read on this all say the same, but if you have to buy a set of wire extensions I will bet they will be indicator extensions which will set you back about $20. Are you wiring through your bars?
  • rix181
    rix181
    Hey guys thanks for your tips now all I have to do is wait for them to come from the States cost $38 instead of  $214 genuine.I'd like to buy genuine but at that price difference I can't justify it.
    cheers Rick
