If replacing my Rotor and Stator should I replace the regulator as well? Im pretty sure the old one is 22 amp? The new Rotor/stator is 32 amp which suggests I need to upgrade the reg to suit?
hi i would be buying a brand name type set reg & stator , like original HD or ACCEL, Americian cycle electric , the there's a lot of cheap crap out there , china
And just make damn sure the regulator is earthed well or you will be fitting another one....and another one....... If its on a rubber mount frame, its a good idea to run a separate earth wire from the regulator mounting to the motor just to be sure there are no spikes.
