Online: beaglebasher
Hi from Steve In Woodcroft SA
  • Steveler
    Steveler
     HI all im Steve from Woodcroft in SA , been following the Forum for a while and thought i would join . I currentily own a 2007 , 1580 CC Heritige Softail Classic , had the Harley since new , done a few  big rides  , eg  up the West Coast of West Oz , Phillip Island,  and various other rides around the Country side.  Getting the Chrome thing happening  , And booked the Heritige into PS in Adelaide for  Big Bore 113  Screaming Eagle kit . Much to the Mrs Disliking , oh well .
    Regards Steve
  • Outlaw72
    Outlaw72
    G'day Steve.
    Good to see another Crow Eater mate.
  • Steveler
    Steveler
    Thanks for that , much appreciated .
      Steve, enjoy the forums, ride safe.
    Welcome Steve , the 113 kit sounds the goods .
  • Steveler
    Steveler
    Thanks for the Welcome . I was thinking of getting the 103  big bore kit for my 96 cube motor  originally , but for  the extra  $ ,   the option of getting  the Screaming Eagle , Barrels , Heads , Pushrod and Cams , Throttle body machined up,  Screaming Eagle tuner  , and getting the cases machined , and going to 113 Cube option  , I hope will be the go?   .
    Regards Steve
  • ozymax
    ozymax
    welcome to the board.
  • Fatman
    Fatman
    G'day & welcome...enjoy the Forum
  • Toto_jp
    Toto_jp
    Welcome Steve
  • AJ56
    AJ56
    Steve are you getting the bottom end done at the same time.? I have an 07 Heritage and the 07 had issues with the bottom end. Twisting cranks.. if you are going to spend the money I would seriously look at getting you cranks inspected before to confirm what is required.
    HH will put the 113 in and then wipe their hands of you if you have an issue with twisting cranks/excess vibration etc.
  • Steveler
    Steveler
    Thanks for that advice , I didnt know that , i will  ring H H ,   and ask  them about the crank , I do know they are sending the bottom end of the motor , to  there Melbourne Machine shop ,  to get the bottom end machined , so as it can make the new Screaming Eagle Barrels fit .
  • fattatt
    fattatt
    Welcome.
  • Glenno
    Glenno
    Welcome Steve
  • Scruffy
    Scruffy
    Hi Steve
    Welcome aboard.
    Good to see another South Ozzy.
    Catch you on the road.
     G'day and welcome to the forums.
  • jacks
    jacks
    Welcome Steve, a friend had the 103 kit fitted and had trouble with the bottom end on her 96 motor, but once fixed goes great now, if you'r getting the S/E kit fitted maby you should also think about a stronger spring in the clutch...naturally only if you ride her hard...have fun, the little lady will love it once she gets on behind you...
  • jye
    jye
    Welcome to the road
