Hi Guys and Gals,
Not sure this is in the right section but I need some help in identifying my existing set up and then installing appropriate TTS or similar if required. Here's a bit of background info.
Bike 2006 (11/05) Dyna Lowrider FXDLI
Screaming eagle Baloney cut exhaust
I have no idea what else may have been done. I have looked back through some of the service history and can see the purchase of the pipes but nothing by way of intake or ecu upgrades. I purchased from a dealer and have books etc and address of previous owner bt I really didnt want to other him unless I have to (although he doesnt live that far from me.).
Bike is running very lean (I think) on decelleration as has a noticeable popping sound (Pull clutch in and it goes away).
Seems Ok on accelleration as not flat at all but I am not as certain about that.
Rider I am around 105 Kg and will be 40% 2 up with Mrs who is 58 Kg. It has standard suspension but this will very soon be upgraded to Progressive 412's HD with Progressive fork springs. All standard OEM length.
This is my first Harley coming from Sports/Naked and classic bikes. This is the first non carburetted bike I have owned.
I would like to know:
1. How can I identify what if any upgrades have been made to ecu etc as I thought something would have been done re: new exhausts.
2. If I am running too lean on decelleration would a TTS style unit be appropriate to fix.
3. I am a novice with Fuel Injection systems and mapping so is this difficult to install and "map"
4. Does "mapping" need to be changed dependant on Climate, Altitude, riding style etc or is it set and forget.
5. Should I do a baseline dyno run somewhere before I start all this.
6. I am thinking of a S & S or Screaming Eagle Big Bore kit in the next 12 months or so as the bike will need a freshen up soon as done
around 110,000 klm's. Will I need to change the TTS ( or similar) unit then or is it a "remap" type situation.
Thanks and Ride Safe
Nigel
It fixed it on my sportster 1200 after vtuning.
A monkey could do it with the TTS, as long as you read the info.
If you do TTS vTune then you have set the bike up for your area etc..............
Save your money and buy a A/C for your bike if it still has the stock A/C, vTuning is dyno tuning without the dyno
A typical VTune screen after 30 minutes of riding is shown below, Figure 4-14. For comparison purposes, a VTune run taken on a dyno is also shown. The Dyno run allows access to regions that are difficult to get and maintain during closed course riding – but, a closed course VTune session will cover 95 percent of your normal riding conditions!
Figure 4-13: Closed Course VTune Data
Figure 4-14: Dyno Generated VTune Data
I would start the vTuning again as you have changed your engine setup.
I'm redoing my vTune now as i have changed my A/C to a Screamin' Eagle® Sportster® Stage I Air Cleaner Kit
Hey guys thanks for the info.
