Triple Trees
  • calais
    calais
    G'Day All,
    I ride a 2011 Dyna Street Bob, and want to get the rake that the Wide Glide has.
    Its the one thing the Wide Glide has that I want for my own bike. Only problem is, I have NFI who or what to ask for in order to rake my ride.
    I was thinking its a set of 3" over trees for a mid glide front end? What is the simplest / most cost effective way of getting what I am after? Who would people recommend?
    Cheers fellas.
  • calais
    calais
    Ive been looking at the Hawg Halters website, the gear on there looks pretty sweet, am I right in thinking that I will need a new set of trees, and a conversion kit which has a new front axle, some spacers and bolts etc?
    http://hawghalters.com/
  • calais
    calais
    Looks like an oem kit would be safest hey?
  • calais
    calais
    All good mate, I appreciate your input. Your bike looks right with that rake. I like it.
    Pieter from P&L in Toongabbie is looking around to see what will work out for me, and he said the same thing about the cups.
    One thing I dont need is my otherwise great riding bike turning into a heap of shit. Do it once, do it right :)
  • the_mongrel
    the_mongrel
     Mate, the Hawg Halters Raked Tree kits are the bomb!!
    I bought the 4dg Raked kit for my fatty and it rides better than it did stock.  I have had my hands off the bars at 140km and NO wobble!!  It corners better and it looks sick!!
    I did the install myself, and it aint that hard!!   No raked cups (no disrespect to the above) just saying is all.
    Below are some before and after!!
    BEFORE
    AFTER
  • the_mongrel
    the_mongrel
    Yeah man - I do like the Corsair, but it was getting in the way too much - so I have the MoFlo on now, and it goes just as hard. :) I still have the corsair incase I get bored. :)
    Yep - I am loving the raked trees.
  • Gilbo
    Gilbo
    Helped a mate do a 3degree wide glide tree install on his 07 Street bob, we decided to add a 21inch front runner and lowered the srse an inch instead of longer tubes. Axle spacers can be a bit tricky to get right if your not careful. Old mate was happy with the end result and can't fault the stability of the ride! Check out J&P parts online, lots of kits to choose from at good prices, delivery time can about 4-5 weeks though ;)
  • Oldman
    Oldman
    I have a set of custom mid - glide, hidden top tree's with 3 degree rake and they were made at A1 cycle engineering.
    Great investment. Hands off at 140+ with no wobble and also corners better than standard.
  • calais
    calais
    Apologies for the dumbass question, but what do you mean by 'hidden' top trees?
    Dumbass qestion # 2 - Raked Cups ? Even the raked triple trees , does this mean the fork tube holes are 3 deg from the headstem line , therefore not machined square through triple trees ?
  • the_mongrel
    the_mongrel
    Agreed! To much rake and it's a recipe for disaster. I have a relative with a softail with 5 Degree raked trees, and man, that thing is a death trap! There is plenty of data about bring the trail back in line using fork length etc. I can't comment on any other setups bar the one I have, and as stated above, it really does handle better than stock, with no ill affect. So I can only gather that Hawg did their research on this kit. :)
  • calais
    calais
    Cheers fellas, I have sure learnt a lot about what I need to carefully consider!
    I appreciate the time you have taken to help out.
