bike idles fast one minute,wont idle the next.
  • oneball
    oneball
    Hi all...Went for a ride today on my Fatboy low.Half way durring the ride the bike was idleing at 2000rpm for about half an hour.The bike then come good.Stopped at mates place for half an hour,Bike started ok,Idled perfect.Headed home and i noticed it wouldnt idle.Got home,still wont idle.Besides that,The bike runs fine.
    Any ideas anyone ????
  • AJ56
    AJ56
    Give the IAC unit a clean with some carby cleaner. They cause issues sometimes...
  • oneball
    oneball
    Hi all...Yeah cookie,Its an EFI 2011 fatboylow.
  • oneball
    oneball
    Hi all...The problem was engine temprature sensor.
  • AJ56
    AJ56
    Would not have thought of that.... Pretty simple fix as well
  • Retroman
    A warranty fix i presume ?
    I have replaced an IAC controller unit before now, almost exact same symptoms !
    Mine was Waaay outta warranty tho'..
  • oneball
    oneball
    Hi all...Yes,Warranty.
