Best way to legally build a rigid Sporty?
  • Damon
    Damon
    I am plagued by the need to build a rigid bike, but one that is legal and registerable. Trouble is I want to do something budget oriented.
    So, here's my question.
    Can I build an ICV using a frame purchased from VPW and the workings of a complete compatible donor Sportster?
    Furthermore, do VPW offer a rubber-mount compatible frame?
    If the answer to both questions is 'yes', then is there any reason I can't buy a Nightster in the USA for about $6500 (going rate for an older stocky) and import it to be used as the donor bike?
    If this is all feasible surely a rigid Sporty has to be a viable and very affordable project via this route?
    Thoughts?
  • TC883
    TC883
     Damon, maybe try a pair of rigid struts on the rear of your Iron to see what a rigid is like to ride for while? TC
  • Damon
    Damon
    Meh, have ridden a couple of rigids, plus I'll be running a spring seat.
