Online: Retroman, speedzter, Uncle Ho
Gear box/Primary volume
  • Sparra
    Sparra
    Just moved house and can't find my manual...Can anyone tell me the amount of oil needed to fill the gear box and primary on a 1995 FXSTC...
    Cheers...Sparra
    hi there sparra the primary is normal  1 qurt or 1 litre  and gear box is about 800ml memory ,you should have a dipstick on the gearbox fill plug
  • Sparra
    Sparra
    Cheers...Thanks mate...
  • Burnzi
    Burnzi
    91 on 590-710 ml
  • Burnzi
    Burnzi
    Download the 84-99 Evo file thingy from Reference Docs/How to guides. (Reference Section at the bottom of the Forums page) By The Don. I bought the CD on ebay before this was on the site. Tells ya heaps
  • Sparra
    Sparra
    Cheers fella's....
  • Burnzi
    Burnzi
    Sorry mate, cos I bought the CD I have never tried the download. If you need any more info PM me and will see what we can work out
  • The Don
    The Don
     Hi Sparra,
    checked on the download site and after a couple of tries it worked. They certainly try to get you to download all sorts of other crap amongst the links. Just ignore anything apart from the link to the file itself.
    Cheers,
    Cris
