Rear brake pad removal
  • Vetman
    Vetman
     I have a 2011 FXST Softail Standar , Im not near my bike at the moment but a guy here reckons you cant replace the rubber pad on the rear brake pedal with anything else because the rubber pad is part of the brake pedal. I find this hard to believe, surely its screwed on from underneath or somthing... truth?
     G'day Vetman, You can replace your rear brake pedal. Your right, it unbolts from the bottom. There are two sizes of brake pedal. Large for the FL softails,  and small for the FX softails. Only the small pedals fit on your model with the forward controls.  Hope this helps.
  • Vetman
    Vetman
    i meant the stock rubber pad. I want to change it out for metal
  • Vetman
    Vetman
    it appears to be stuck on...
  • Vetman
    Vetman
    Am i supposed to pry that rubber pad off and then screw / bolt an aftermarket one on?
  • FLSTC
    FLSTC
    start with the assumption that anything is possible and go from there... have you sourced a small metal plate to replace it ? and considered how it will be attached ?    you may also find that replacing with an aftermarket pedal could be an easier exercise
  • Vetman
    Vetman
    i havnt considered much really mate, i just love skulls and want to have skull hang grips and pegs
