Online: inkaporka
Fuel pressure
  • Dardytree
    Dardytree
    I have a 2008 Fatbob with 63000 klms , my fuel pressure is down  therefore lacking power ,  cant see any leaks & was wondering if the fuel pump may be worn out . Anybody know how long the last ? Cheers
  • AJ56
    AJ56
    When did you change your Filter? If that is blocked then it would reduce the fuel pressure and put added strain on the fuel pump.
  • Dardytree
    Dardytree
    Thanx for the reply mate but yep , did the filter now i'm stumped , mate told me today his Street Glide has 160k on it & pump still ok
  • AJ56
    AJ56
    Have you tried running the pump without the filter just to check fuel pressure. Also you may have a split in the lines inside the tank. If they get a split then you would loose pressure. Did you use a proper gauge. I think the pressure should be around 60Psi.
  • Dardytree
    Dardytree
    Pressure was checked at local HD dealer at just under 40psi , i cant see any leaks , splits inside tank ( when ignition is turned on ) I will try it without the filter in , thats good plan right now , thanx
  • AJ56
    AJ56
    Also check your Fuel Pressure Regulator as well. Possible that the o'rings have perished or the unit is causing the problems
  • Dardytree
    Dardytree
    Sorry guys , took a while to get back , ended up putting a new pump in ( after buying the wrong one first ) & the new pump is great! Old pump had done 63,000 ks & i have been told it should have lasted a lot longer , but no matter is great now , thanks for the input . PS : pump was $216 from Peter Stevens in Melb , i got it there coz i bought the bike there
