Hi Guys
Can any one help
20102 V-rod Muscle, Tab slip on pipes, K & N filter
TTS master tuner
Having problems with set up
Reads ECM date
When go to save Factory EMC data it gets about 35 to 50% then brings up error Access 1 denided,,,
Have tried a number of times and also get error 502, 504 and once got error 280
Using the USB cable supplied with the TTS kit
Been through all the set up and down load instruction a number of times
Probably something real simple, any ideas
Thanks
Hi Slick
have you had any luck sorting out your problem with tts mastertune ?
I had my 2010 vrcdx in for a tune with Phil Taiton they have a similar problem.
Yet to be resolved.
Cheers Bazza
Hi Bazza
No no luck in sorting the problem
The distributor sent me a map to download,, that worked,, but when tried to save the original ECM setting got the Access 1 denied error AGAIN so had to not save the settings. Sent an Email to TTS in USA but no satisfaction as yet,,,The Distributor Steelhorse in QLD said they had similar problem they said they were going to contact Steve Cole,, but once again nothing
Not happy at all
Hi Steve
The cables where supplied by your distributor Steelhorse in QLD
What about the error,,,,,,, Access 1 Dinied ,,,,,what does that mean
Sent an email to TTS on 7th May 2012 ,,, had to follow up on 11th May,,, got reply on 11th that it was being passed onto Tech department
Now 21st May and no reply or solution
Very disappointed in the product and the service from TTS in the USA
Steel horse in Australia have tried their best and been most helpful
Not sure about any email but I gave you what the codes are telling us above in my May 17 post. Access 1 denied just is telling us the ECM is not allowing the TTS to work most likely due to one of the codes you posted. At this point what have you done to try to resolve it? As Hilly stated trying a different set of cables MIGHT be the answer, it could also be your PC causing an issue I just do not know for sure. Are you located close to anyone else on the board that might be able to help you out? Being as I know nothing about your area that maybe much faster then shipping everything back to get checked out.
I just want to try and get whatever problem you have solved as quick as we can.
Is there anyone in the Croydon Vic area ( outer eastern Suburbs) that may be able to lend me set of TTS cables to try and establish problem as per above posts.
Big tanks for all your advice and offers of help
AJ56
Will give a you a call if I need your cables
Question
If there was a problem with the cable/s then why can one download ( have installed map) and not be able to upload (same the settings)
Hi Retroman
What is a Belkin F5109 ?
