Online: beaglebasher, John.R, Hilly
HELP NEEDED REMOVING RH FOOT PEG ON THE XL
  • pan head
    pan head
    Anyone can assist me with the instructions to remove the RH mid control FOOT PEG on a 1991 sportster.
    Any help is appreciated.
    Pan.
     you have to take the exh pipes & the rear master clyinder off to take the alloy sprocket ( pulley cover off ,    the peg mount is bolted from behind the cover  if it's come loose use loctite on the thread,      also check the main belt pulley nut for tightness while your in there
  • Warblade
    Warblade
    isnt one side clockwise, other anti clockwise?
