REMOVE RH FOOT PEG XL SPORTSTER
  • pan head
    pan head
    Anyone removed the RH foot peg mid control on a 1990s Sportster.  Having a little trouble, any help is appreciated.
    Pan.
     best take the  sprocket cover off the bike if you want too tighten or remove the main mount as it is bolted from behind the alloy cover  that means taking off the exh system + the rear brake master cylinder   before you can take off the sprocket or pulley cover , check main pulley nut while in there also
