H-D special purpose grease
  • Big H
    Big H
     Does any one know of a replacement for the H-D special purpose grease used for packing the neck bearings of late models softails?
    Local stealer is out of stock and I need to pack two bearings,
    just use any good brand bearing grease from any good auto store the hd stuff will be just re branded ,dont over pack the stem as the grease can leak out over time and will go all over your clean ride.
