I need service tools
  • HOPPY
    HOPPY
    Getting myself ready to do a good service on my 02 Sportster. Theres no need for me to borrow tools so Im best to get my own. I have a motorcycle jack and service manual waiting to arrive!
    Just looking at the bike I know Im going to need a set of
    Imperial Spanners
    Imperical Socket set
    um Imperial Allen keys, or ive seen a set were the hex shape attaches to the ratchet?
    and those star shaped bolts? the tool for those are called??
    would there be anything else I should get a hold of?
    star shaped bolts are torx bolts you will also need need metric due to anything after market on the bike normal use metric sizing,(made in china)
  • Ross
    Ross
    Depending on far you plan on going, a torque wrench.
  • HOPPY
    HOPPY
    oh yep, should mention, i have metric spanners, sockets a couple extensions and a torque wrench - its just the imperial stuff i have nothing of!
    do i need a full set of torx sockets or is there only like 3 or 4 sizes that you need?!
  • houli
    houli
    4lb hammer and lots of patience.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    trade tools direct sell some great cheap torx socket sets for round 30 bucks i got few sets found the impact type for doin discs ect normally dont last long so get a good set the bigger sizes if ya gunna do discs an pulleys an dont forget a good oil pan or as i do a metal spill tray from supacheap for 10 buks will fit great from front tire to rear under bike an catchs any thing that may drop fall or spill
