Flht '87' need a different front end? What could I use?
  • Danielmustang
    Danielmustang
     Hi, guys just need some ideas on what can be done with a 1987 flht front forks and trees? The stock ones are opisite to a normal set up, like they are reverse. I want to do away with the big cowl at the front and put anything else on, but will the gap between tank and forks look silly? I can't find any info bout doing this, maybe people don't play with 87 flht's? Any ideas or tips would be apreciate, thanks
  • Danielmustang
    Danielmustang
    Sounds good I'll probably go with a heritage front, now I just need to find one, is there like a Harley wrecker around, or were would the best place to find one? Thanks for the info, really appreciate it
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    ebay has some cheapies or try ya local non dealer shops most round 500 to 700 are a good buy
  • Danielmustang
    Danielmustang
    i finally got a front end!! ill post up pics later, i got a fatboy 2000-2006 front forks in black, ive sat em in now ive got bugger all turning circle, should i A. cut the fork stops or B. notch the frame in a bit were it comes into contact?? i just wanna get it done so i can get it all sent away for paint, thanks guys,
    p.s ill put some pics up here tonight when the missis can show me how
  • Danielmustang
    Danielmustang
  • Danielmustang
    Danielmustang
    There's the pics
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    get some tie downs an tie ya frame to jack that way ya can get the guard out an not dent it maybe ..you can trim the stops but as said above put tanks on first if you still find you not much turn you can put dyna wide glide trees on which will bring them forward an bit
