Online: FONTANA302
Offset sprrocket
  • butza
    butza
    • Gday , can anybody tell me if a 1/4 inch offset sprocket will clear the inner primary case on an evo !!
    • Cheers.
    s
    i pushed the wrong button,      sprocket should go on as the front pulley is alot wider than that sprocket . but not on a very early model  like 1984 -86 type ,    in testing use modeling clay as a dummy run check on inside of pri cover ,    just put oil on 1 side so it does not stick & pull  so the measure is correct
  • butza
    butza
    Thaks Daddy racer!! i ll check it out.
  • butza
    butza
    Ok after checking this out , i noticed that the existing pulley is much larger in diameter than a standard sprocket , and with the inbuilt recess in the pulley it misses the casing pretty easy. The sprocket being smaller with a smaller recess out of the face of it looks like there is only about an 1/8 of an inch spare.
    Anybody know if a 1/4 inch offset pulley will fit!!
  • butza
    butza
    Come on , somebody must know the answer to this question!!
