Online: John.R
Silver denim paint from HD USA
  • ozymax
    ozymax
    1/2 oz doesn't sound much.
    For repairs on panels there are some very talented painters around that could colour match it if the had a painted panel to work with. I had a front guard done on a kawa years ago and it matched perfectly. he had the original guard to work from. wasn't cheap by any means but he did a fantastic job
    If all you want is a little at home to touch up the odd stone chip I'm not sure they could do it. Cant you get the paint code from the bike?
    I'm guessing you mean Pewter Denim... or do they have a silver now?
    A painter in Perth said he had the numbers back in 2007... gave them to me with a sample pot, but will take a bit to find as have archived emails back that far.
    I also put a touch-up kit (2 part kit) from HD in 2008.... both didn't match well, but then I really don't think I applied it correctly to the stone chips.
    I will try and see what I can find tomorrow.... the HD paint is in storage in Adelaide so wont have those details till late May.
  • ozymax
    ozymax
    The guy I used matched it by eye not computer spectrum style. depending where you are and what you want done guys like him can do it. (Hans Kreuzen)
    maybe the code is on the bike or in the owners manual of a bike that colour?
    maybe try 1130cc.com
  • Glider
    Glider
    there is a ppg paint supplier who can mix the harley codes, they are in yennora sydney
    i got a spare set of silver denim for my nightrain 07
    what are you painting?
  • HogBag
    HogBag
    Glider
     I gave them a buzz and they can mix my pacific blue paint for my tour pack.
    Platinum auto paints Yennora 0296323400
