Carrying a swag on street bob?
  • Iolis
    Iolis
    Hey guy's i own a street bob 2012 done a few trips but need to take a swag or tent and sleep bag, only thing is it's a single seat no rack etc? How do you guy's load a single searter and what to use for tie downs? Without scratching the paint.
  • dangerousdave
    dangerousdave
    I have one of these racks on my street bob. It also doubles as a pilion.
    http://www.hdforums.com/forum/dyna-parts/739328-street-bob-rear-fender-rack-52796-09-a.html
  • Gilesie
    Gilesie
     ive put a passanger seat on mine and longer fender bolts in to hook the okky onto, or you could try the bars depending on the size of your swag
  • Iolis
    Iolis
    Thanks guy's the link dangerousdave posted looks the go so i can take a pillion sometimes. Cheers fellas.
    I use various options...
    1. Have detachable sissy bar and pillion seat for larger swag/bag etc
    2. For smaller stuff I have the rack that fits in place of the detachable sissy bar... sits over fender... where pillion seat normally goes
    3. For small stuff like wet weather gear etc I have a fender bib (helps protect the fender from pillion seat as well) and place the gear on that and use occy starp to the detachable sissy bar/indicator mounting points
    Hope this helps
  • Wimbo
    Wimbo
    Fender Bib and Sissy bar plus a saddle bag or 2.
    You can hook a sleeping bag to the top of a saddle bag.
