Online: DC67, Wanderer57
Seats, again, trying to work around numb nuts...
  • ShredMaster
    ShredMaster
    So this is fucked, surely some other fuckers have run into this...
    I took a ride up to my parents place about 2hrs away up a winding range and several lenths of 100km/hr straights with a few turns and back again...
    Fuck this, I get about 45mins into it and my nuts go numb, I get pins and needles in my arse and I have to pull over and stop for a sec.   The minute I get of the bike I get a blood-rush to my nether regions and walk around for a smoke's-worth and its all good again for another 45 mins or so...
    I reckon its my stock-standard solo seat on the Iron but this is just stupid engineering if that's the case.  I'm a relatively short fucker, average height of a woman at 165cm with mid mounted pegs and I've tried all the tricks:  change posture, spread legs, move feet back to the ball of the foot on the pegs or perhaps forward so its the heel etc.
    I can't stand numb nuts on a ride like this and it's ONLY a cpl hours...
    Is this normal or am i doing it wrong?
    Cheers,
    Shred.
  • BAKES
    BAKES
    Your stock seat is all about the look, if you are after comfort, where you can ride all day go for something like Muffin metioned or a sundowner, I have the sundowner and can ride all day with no issues.
  • BAKES
    BAKES
  • PK2
    PK2
    That's weird, I've ridden all day on mine with no issues (Melbourne-Canberra) at all. I do use the pillion pegs a fair bit on the highway, but even with a pillion so I can't use those pegs I don't have an issue.
    That's the stock seat.
  • 883n Harley Convert
    883n Harley Convert
    Mate, I have the Sundowner for long rides and its fucking amazing................no issues, comfortable as, but it looks like a dogs breakfast!!
    If you want comfort, definitely have a look at the Sundowner. You will pick one up on eBay second hand pretty cheap if you dont want to invest a fortune!
    Will resolve all concerns!!
    Waz
    883n Harley Convert
    Cricket, just at the gym mate, will post the details for you tonight when I get home.
    Waz
  • terroristone
    terroristone
    im short as well, 5'6" and 58kilos, i found the stock seat fine, i did find that i was getting sore in the hips a little, i've since swapped it out for a la pera barebones (a harder seat) i did a 850k ride and didn't have too much of an issue, the la pera moved me forward a little, and lower. Even after fitting forward controls it feels much the same, i still get sore in the hips so i swap to my pillion pegs for a few mins and even sometimes resting my legs on the primary case just so you get to move them around.
    T1
    Without getting to fruity here - if you wear boxers try briefs. And make sure you move your nuts into a comfy position before you ride - when sitting on your saggy balls pain is natures way of telling you to fucking quit it.
  • Fire511
    Fire511
    For long rides only im thinking of one of those airhark seat pads. If it looks like shit I will save it for long rides, and if you dont like it you can return them and get your money back.
  • kevlad
    kevlad
    Fixed the problem i found an old seat then had it recovered with new foam HD must get foam from old rooted couches its shit while i was at it i gave the cook and extra inch to sit on she likes it
  • ShredMaster
    ShredMaster
    Nice feedback, alot to think about!
    Warblade, just to clarify, I'm not from Thailand...
    I do think perhaps a harder seat would be better, strangely enough.   I desperately want a spring solo seat thinging that it would alleviate the issue being not only sprung but more narrow and kinda "arse-y" i guess.  Less pressure on the crotch holding all the wieght of a tubby fucker on a bike.  But damn, $300 odd for the seat is expected but $350ish for the bracket to fit the seat is just mindboggling!   I kinda wish I changed the seat when I financed the bike and tied it all up in the one contract rather thant trying to explain to the Minster of War and Fincance how I should justify such a setup because of my balls, which she has not much understanding of except don't whack em!
    Interesting feedback on the pillion pegs, I didn't get any due to making my rego more expensive by about fuck all but still, its the principle!
    Cheers,
    Shred.
  • TC883
    TC883
     Shred, I just put a 48 seat on my Iron. Got it from another forum member, but they are about $150 new from a dealer I think. It's lower than the stock seat, narrower and yet better padded and no less comfortable. The best part is you could try it out by going to a dealer and sitting on one. Just another thought. TC
  • ShredMaster
    ShredMaster
    That's not such a bad idea tbh and I'll do that!
    Really though, I have no issues with the stock Iron seat unless I take the bitch on a longwinded ride where I spent 40mins-1hr on 100km/hr straights with only a few turns...
    It's not that I have such massive balls of of steel (thank's for not pointing that out), it's just I seem to be sitting on em for too long at a time...
    /shrug!
