Online: Stuart, Uncle Ho
What's the best mods to achieve the most horsepower out of my 2008 96ci softail
  • GreasySoftail
    GreasySoftail
     What's the best mods I can do to my 2008 softail custom withouth having to crack open the engine to achieve the best horsepower and tourque it can.  Also the best places I can find these parts ad where togo. I'm in Brisbane so localy would be best. Cheers josh.
  • GreasySoftail
    GreasySoftail
    Yeah I'm not sure how the nos would go haha. I'd love to have something like a vrod set up for drag racing like that but not my everyday, Too and from work transport haha.
  • robcig
    robcig
    Cams, air filter and free flowing pipes best bang for your buck.
  • fastapastor
    fastapastor
    Look up S&S website they give it to you in 4 steps. Sure enough the last are pistons and cams etc. As much as I agree Nos is a cheap HP gain its illegal in Qld and can get ugly and very expensive if it goes wrong. My 2cents.
  • Henry
    Henry
    I went this way  everything else was stock no head work, etc.
    if you do a search on procharger I did a report from when I first installed it a couple of months ago.
    Since then I have added cams and am now waiting on a scorpion clutch as the standard one doen't like new HP but I only did the cams because I like a lumpy idle on a Harley, not because it needed it. Some people have said not worth the money, or "why" but 99% of them have not ridden a supercharged bike.
    The way I looked at it 7K bolt on horsepower to acheive before the cams 115HP or the usual big bore kit, cams, headwork etc that was being advertised for 5K for 100-105hp (yes I know you can get it cheaper but that is what was being advertised at the time).
  • Henry
    Henry
    Sorry I forgot to add I ride it most days, and the power is there 100% of the time from idle through to rev the limiter, and it becomes very adictive.
  • GreasySoftail
    GreasySoftail
    hey guys, i didnt mean to start this massive debate on what i should and shouldnt do, just after a few cheaper ways to get the most bank for my buck. and where abouts anyone would recomend and parts. only want to spend about 2 grand max being an apprentice on fuck all wage.
    cheers!
  • PUNJABI_DuDE
    PUNJABI_DuDE
    Hey Greasy don't want to be smart ass but can I ask why not to crack open the engine (any bad experience in past?). As you know so many of us has gone that path and it is proven and worth it? But then to each its own
  • GreasySoftail
    GreasySoftail
     hey punjabi,
    origionaly i didnt want to spend a fuck load of cash and just get a cheaper "bang for buck" sort of thing. i thought that cams and all that would be $$$$$ but learning more and reading more ive seen that its not as pricey as i had thought. do you have any idea on the whole thing? im new to the fuel injected bikes and new to harleys so i have no idea about what mods are worth it or not.
    cheers!
  • PUNJABI_DuDE
    PUNJABI_DuDE
    You can look at screaming eagle 103 stageIII. You can get that for around 1200 with se tuner. If you already got se tuner then u can sell it off and use that money for labour. I am guessing stage 3 will cost around 7-8 hrs.
    This is something I will be doing once I get over stage 1 which is enough fo me at present.
    Btw this set up will get you around 100hp/100tq.
    Let us know how u go. Good luck
  • PUNJABI_DuDE
    PUNJABI_DuDE
     Hey Greasy
    Sorry to get back to you late.... here is the link www.gotharleyparts.com/category_s/152.htm you will need some1 in states to post you the stuff though as they don't send overseas (I asked on the phone)
    you can even choose between stage 1, 2 or 4. But for me stage 3 will work out good ... good luck
