If I had hair I'd pull it out. 1991 Ultra Classic Electraglide EVO wont start. Petrol is there, plenty of volts, starter cranks well, sparks are there, just backfires.
have you checked the timing,was it running recently and was it running ok then,crank sensor possibly just my 2 cents
It was running clarkie, ok but not 100%.
Remember the anagram FAST 1. Fuel
2. Air
3. Spark
4. Timing
For the engine to start these 4 things must be correct.
Fuel could be stale, perhaps the wrong fuel or fuel filter blocked.
Air Filter could be completely blocked.
Spark plugs are clogged up; gaps wrong or passed their use by date.
Timing, self explanatory.
Thanks guys, Bugger me it just started first pop and I took it for a blast no probs. The pattern is next time just as likely to not start and backfire.
