Online: GGUser743, B0nes, HD17, Hilly
Drag Bars 48
  • maachine
    maachine
    Wanting to put on 0 rise drag bars with 4" pullback on 48. Just wondering what bars people have used with this spec and if they had any dramas with clearances etc?
  • slapster
    slapster
    I put the HD drag bar part# 55800035 (satin black $88) on my Iron. No clearance issues, have flipped mirrors & my tank is bigger 3.3gal.
    http://www.harley-davidson.com/gma/gma_product.jsp?PRODUCT%3C%3Eprd_id=845524448777077&default=none
    Slap.
  • PK2
    PK2
    I run a broomstick (no pullback) on my Iron and love it! I use the pillion pegs a fair bit on the highway and love the riding position.
  • maachine
    maachine
    Thanks guys. The 48 is a bit different than the Iron as the triple tree is wider and the handlebar clamp set lower.  Looking at it, it looks like if 0 rise bars are put on then it may hit the top fork nut. May be just a case of loosening the pinch bolts and lowering the forks a tad.  Also it looks like there is no way 1 1/4" bars will go on, will have to stick with 1" bars.
  • maachine
    maachine
     Thanks for the part number Slap. Ordered this morning, put on next week hopefully with Joker Machine speedo relocation.
  • slapster
    slapster
    Yeah no worries. I'm looking at the autometer bracket, cheaper option to relocate speedo. Joker do a top clamp with integrated dummy lights. All up cost about $110. Worth considering.
    Slap.
