Online: Hilly, speedzter
Head Light bulbs
  • Cyborg
    Cyborg
    60 watt high beam you have got to be kidding,I changed to 80/100watts with the only problem being broken by vibration but at least I can see were I'm going.
  • imoo6170
    imoo6170
    I tried the Vison Plus's in my car - seemed to blow one every couple of months - Had the car checked and all seemed ok. Went back to the std bulbs and did have a problem.  That was in a 2000 Mazda, not a bike but still put me off.  Tried this in about 2005 so it was a couple of years ago.
    Will be interested to see how u go with them in a bike.
  • twincam88b
    twincam88b
    I heard that a Harley won't run when the headlight globe is blown???? True or what.???
  • imoo6170
    imoo6170
    Mines a 98 and it ran ok with the bulb blown - only way I found that it had blown was the high beam indicator stayed on. Checked the light and the bulb was history.
  • blueystar
    blueystar
    just fittered blue dot try bar 55/60 watts head light and blue dot try bar 35 watts spot lights to the road sweeper and they give more light out front than i need
  • Fr3d
    Fr3d
    My 08 RKC using stock 60/55 bulbs is brilliant! You can see as well as in any well lit car. Then turn the passing lights on and you can go spotlighting. As found out trying to getter better light on my wide glide, it all in the reflector behind the bulb. The modern light has better faceting for directing and concentrating the light much better. You will notice the new bikes have clear lenses as opposed to the old style where the light was diffused and faceted through the thicker glass lense. If you use too higer wattage with the new bikes, its possible you will melt or distort the plastic reflectors. The older RK probably have chromed steel reflectors though. I would look at a new reflector and lense before the bulb
    Fr3d
