Online: WideglidingNZ
Tyre wear
  • hellboundpig
    hellboundpig
    Fitted a 210 50 17 metzler rear tyre to my 07 softail standard it has done 1800 kms on this tyre and it is worn down to the wear
    indicators in the middle and square or cupped this tyre is rooted iam going through a shit fight with my west oz metzler dealer at the moment
    this tyre is unsafe any one else have problems with the 210 on a 200 rim .
  • Mainey88
    Mainey88
    shit thats a quick run out, sticky compound = good in wet but poor tyre life, good luck with the dealer, would like to know how ya get on mate.
  • hellboundpig
    hellboundpig
    Mainey 88 metzler dealer wouldnt come to the party saying the 210 marathon is a soft compound sports tyre not a long wearing tyre
    sounds like crap to me local bike shop said they will fit a knew 200 dunlop on for half price and no fitting charge best i can do i reckon .
    and no i dont do burnouts.
  • Peter
    Peter
    Its still bullshit, I used to run a soft compound sports tyre on the back of the VTR1000 and then flog the shit out of it and still got 4000km or more out of it.
  • nobody
    nobody
    Judgeing by the information given,I would suspect that the problem isn't just the compound.I would think that if the tyre is a sports bike tyre then the load rating on the tyre wouldn't suitable for the weight of a Harley.This would also explain cupping etc.as the tyre carcass would be deformed.The amount of heat generated in an overloaded tyre can destroy a tyre very quickly.Probably lucky you haven't had a blow out or an accident.
    nobody
  • Peter
    Peter
    If that is the case I would change the place I buy my tyres because they don't know what they are doing.
  • hellboundpig
    hellboundpig
    screw the crap metzler give me back a Dunlop the tyre in question was ment to be for cruisers so i think its metzler and the bike shop fault for fitting it
    lucky i dont smoke up whats left of it in the shop.
  • hellboundpig
    hellboundpig
    mainey 88 the metzler was a great handling and a smooth riding tyre got a knew dunlop fitted yesterday for 150 bucks they are going to show the tyre to the metzler rep
    while i was there the mitchelen rep said they were going to have fatter tyres for harleys soon something else to try in the future .the reason i change my dunlop in the first place was because i got a half a pair of small scissors through the tyre .
    07 softail standard
    vance & hines big shots k&n thundermax with autotune
    burley t bars lapera bear bones seat
    andrews cams.
  • hellboundpig
    hellboundpig
    http://www.youtube.com/watch?v=7b7q7dwuDF4
    best thing for metzler
  • andij
    andij
    iget 8000klms rear on k591 dunlop there soft but handle well ,u should get at least 5000k out ot sport tyre unless u got dud tyre or
