Online: Stuart, Uncle Ho
Rear End Wobble
  • Roosta
    Roosta
    Just after some experiences if any on Late Model 2010-11+ Softails with 'The Wobble"
    Is anyone still experiencing this? I would have thought HD would have ironed it out, but reading the 'True-Track' website, it appears not.
    As a first timer on a HD (Still waiting for my bike BTW) I have spoken to mates with customs, and they have experienced this, but their bikes are all pre 2010.
    Is it that the rear swing arm is rubber mounted and thus has some play or loss of ragiditity through-out cornering and higher speeds? or is it to do with the shock absorber geometry?
    Appreciate any feedback..
    Blue.
  • chriso
    chriso
    Prob does not help ya Roosta but i got a mate that rides a softy and when i follow him his bike sometimes gets a wobble in the ass end. He says hes used to it and just hangs onto her. ha. he rides as quick as anyone i know too.
    Buy a dyna...... shit did i say that out loud
  • AJ56
    AJ56
    Check your suspension settings, when they come out they are set on the softest setting, try changing it to a bit harder and things might improve a bit.
  • Roosta
    Roosta
    Thanks chriso, but too late mate. A mate has a V rod, and its like riding a fat chick at 180 kph, he's put a 280 on the rear and thinks it's just the tyre size, but it used to wobble a little before with a 260 on it.. Maybe its just what AJ56 suggests, tighten it up a little.
    Not sure ?
  • oneball
    oneball
    Hi all...The newer Softails dont wobble.The older ones were horrible for the wobble.My bet is your tyre pressure to low.Tyre pressure should be 42.
  • Roosta
    Roosta
    Cheers Oneball,
    Haven't got my bike yet, just been hearing peoples stories regarding the wobble, also the True-Track site. I was wondering if it was still a concern.
    Thanks.
