Cobra fuel Injection Module
  • markwoumla
    markwoumla
    Hi All,  I bought a 2009 Electra Glide Standard a month ago. Bike was fitted with a Cobra fue injection mondule. It just so happens that the module installed is for a 2007 Softail, model no 692-1607CL. The correct module for bike is model no 629-1612CL.  I have conflicting advice, Cobra USA says modules are bike and year specific and I should change module. The Australian distributor of Cobra says they are the same module, the only difference is the length of the wiring harnes to fit the touring models, just adjust the pots to the default settings of the 692-1612CL model and your good to go.  Would anyone know a workshop that fits and sells the Cobra module's , or someone that has a Cobra fitted on their bike that could give me some advice.  By the way , the bike runs ok as far as I can tell, (I am no performance expert).   PS , the bike has a Stage 1 upgrade only, (Jackpot mufflers, and SE Air filter). Thanks Mark
