Online: Stuart, Hilly, Uncle Ho
Alarm goes nuts when trying to dissconect battery 08 fxstc
  • GreasySoftail
    GreasySoftail
    Hey guys,
    Yesterday i tried removing my battery so I could diss-conect the trickle charger and everytime I'd get the battery out the alarm would go off. I ended up getting it off bu could someone tell me why it does that? And how to stop it from happening next time?
    Cheers.
  • Warblade
    Warblade
    have the key turned on ready to run when disconnecting the battery.
  • rider
    rider
     Warblade's right.
    you gotta disarm the alarm before you can do anything cause the alarm has it's own battery and sposed ta scare off the burglers even if they try to disconect it.
  • GreasySoftail
    GreasySoftail
    thanks warblade and rider, ill give it ago next time i have to do anything.
  • Gonads
    Gonads
    IIRC the way to do it is you need to turn the ignition on and before the engine light goes out you need to pull the main fuse. Big orange one that clips in at the top left side of fuse box in my 08fxstc.
  • FatRob
    FatRob
     I did mine by whipping the main fuse out when I turned the bike OFF.
    So switch on and wait for it all to come to life,
    Turn it off,
    Whip out the fuse before the alarm has time to arm,
    It's now safe to disconnect the battery.
    The above worked for me on my 2011 Dyna.
    Cheers,
    FatRob
  • Taffymarsden
    Taffymarsden
     Had the same experience and the HD mechanic said just let it scream until the back up battery goes flat. Doesn't take long.
  • Daggs
    Daggs
    yep, what they said
