Online: WideglidingNZ
brass restrictors
  • toxic
    toxic
    Guy's when I bought the Arlen Ness big sucker, after starting to fit it, we discovered that when the breather bolts were fitted, we were to fit some brass restrictors inside the bolts, but there were none in the pack. Can anyone tell me what they are for & who I might get them from, the kit states it was to suit an EFI sportster,
    Any help ya can offer before I continue
    TIA
  • toxic
    toxic
    Called Cassons & they cannot help with the missing bushes, Harley can't / won't assist as it's not a Harley part, so have e-mailed the mob I bought it off & will see wot their reply is.
    Otherwise I will sell the whole kit & get something else.
    Arlen Ness Big sucker stage 1 kit for 1986 -up XL models, if you're interested, hit me.
  • toxic
    toxic
    All sorted, got some info from the XLFORUM, the instruction had been superseded & after some searching, I found the correct bolts, it's now fitted & besides being a big chrome A/C it doesn't look toooooo bad.
  • Hoodaman
    Hoodaman
    Paint it black Tox....
