Online: Stuart
First service
  • pottsy.r@gmail.com
    pottsy.r@gmail.com
    Could someone tell me whats involved in doing first service on harley fatboy or should i get it done at hd shop any tips would be great thankyou people
    pottsy.r@gmail.com
    thankyou mate
  • jacks
    jacks
    Good advice Pottsy, go over her with a fine tooth comb as there are sure to be some nuts etc. that are not tight.
    I then started looking for a good mechanic in the Melb. area....where are you located?
  • dangerousdave
    dangerousdave
    Hi jacks,
    Are there any workshops in Melbourne that you can recommend for servicing after the first.
    What happens with the warranty if you don't use HD servicing? Void? Or are there accredited workshops around?
    Thanks,
    Dave
    pottsy.r@gmail.com
    Tuross head  thanks for your post. pottsy.
