Can anyone tell me what wires run to what for Spyke starter (should be the same as 96 up Harley, I think). I had the original set up with the solenoid on the top of the primary and now have a later model starter to fit where the solenoid is attached directly or part of the starter. Bit scared to connect up something wrong. Cheers Burnzi
12v from battery to starter main power supply nut. mount a bosch relay of black inner rear wheel cover behind oil tank 85 on relay is earth 30 on relay 12v from battery +inline fuse 86 on relay put the old starter solnoid start wire too 87 on relay goes to exciter plug on starter plug
Gotcha thanks mate, having just shifted house I cant find my CD with the wiring manual. Thanx again Burnzi
