running 2 rich
  • red man
    red man
    gday
    my 1998 883 sportster is running way too rich, wondering how to adjust carby so i can avoid having to take it to a mechanic. i pulled the spark plugs out that i put in 3 weeks ago and they are BLACK.
    any help is appreciated
  • red man
    red man
    cheers 4 that
  • Toto_jp
    Toto_jp
    What brand of plug ? my sporty hates NGK leaves them black and sooty
    If you need to adjust the mixture you will have to remove the blanking plug under the carb
    to get to the screw
     idle jet should be a 45 size , main jet around 185 too 190 , mixture screw  3 turns out,   make sure the choke cable is all the way home with a little bit of free play  before you can pull it on  about 1 to 2 m.m. otherwise it's bleeding on ,  the stock white type aircleaner element is very restrictive  causing rich mixture , on to-days fuel you can not read the outside of the plug you must read the white porclien heat shield  around the electroid.  fuck i spell shit after i drink wine
