Cable Repair
  • 883n Harley Convert
    883n Harley Convert
    Hi guys, took my bike out fir her maiden ride today after the work I've beem doing only to find my accelerator cable wedged between the head light mount and frame. As a result both accelerator and return cables are split in the middle. They're custom length cables and will need the outer housing replaced. Does anyone know where I can have them repaired? Cheers Waz
    883n Harley Convert
    Found a bloke in Liverpool (NSW) if you guys ever need repairs, $50 bucks per cable; which seems pretty reasonable to me!!
    Pretty sure I bought new (stock) cables for less than that ?
    What did they cost you ?
    883n Harley Convert
    They're all custom length cables, had them made when I changed to the broomstick bar and they were pretty expensive from memory. Had to get custom clutch, brake, accelerator and throttle all done because the original ones ended up being about a foot longer than they needed.
