Vance and Hines Big Radius oil filler cap problem
  • Gunner
    Gunner
    Anyone out there had the problem where you cant get the oil filler cap off of a Harley Dyna fitted with Big Radius pipes? V&H say i should be able to remove the cap but there is no way the bugger will clear the pipes? Removing pipes to check the oil is crazy. Any solutions?
  • Mainey88
    Mainey88
    gunner I asked the same question a while back on this forum and all the replys came back positive so I brought the big radius and they fitted perfect and I can get the oil filler cap off no worries. I could see a problem though if you havent set the pipes up correctly, you could try adjusting your heat shields around slightly, there are aftermarket oil filler caps around too which may have a smaller head.
