Online: John.R
Roland Sands A?C
  • Roosta
    Roosta
    Hay wallah,
    Do you have a pick of it on your bike?
    And which one did you fit.
    Cheers,
  • Roosta
    Roosta
    Did it bother you when riding that much?
  • Crowy
    Crowy
    By [URL=http://profile.imageshack.us/user/festaasinrot]festaasinrot[/URL] at 2012-04-06
  • Roosta
    Roosta
    Cheers Wallah,
    Sweet ride, looks trick against the chrome of the engine.
    Was this off his site or ebay site mate, If you don't mind.
    I'm 5.7, so I should look at what you've done. Thanks again.
    Bit of a project in the background there mate, love the springer front ends.
  • Roosta
    Roosta
    Cheers Crowy, sits well on the bike. Starting to think this is the A/C for me.
  • Roosta
    Roosta
    Cheers Wallah, will look at their site, appreciate it.
    mates got a 41 WLA, Reverse and all, weird old bike, original army (USA That is) Green. to much touble for me, like the modern stuff. but it's a piece of art, that's for sure.
  • Roosta
    Roosta
    Thanks Ozroder,
    Have had a look at the S&S stuff, but it dosen't float my boat, same to the SE A/C's. I do like the heavy breathers, either SE or K&N, but I don't want to take away from the lines of the bike, want to keep the classis lines of the Deluxe as much as possible.
    Cant find JET, but the Velocity Stack @ VPW look cool, but again, will take away from the Deluxe lines. Not sure how that would affect my leg to brake reach/position. The Alloy Art staff seems ok, needs smaller headed attaching screws and in black. But is a much like the RSD and Kuraykan stuff.
    So its a Charger/Breather type for more power, or a smaller more compact model for the lines. I want both, LOL.
    Will keep looking, but the RSD so far is infront. But the need to be able to get around it to hit the brake pedal is a slight concern for me.
    Thanks for your feedback. muchly appreciated.
  • Roosta
    Roosta
    Just had a look at the High 5 Mk 2, looks pretty trick, cheap on M&M too, cheers.
