Online: Stuart
Changing Oil
  • Superglide2012
    Superglide2012
    Reading in a mag about the residual oil left behind in Harley engines after an oil change. Is it right that up to 1.5 litres of used oil is left in the engine?
  • Superglide2012
    Superglide2012
    Thanks mate. What do they do then at the dealers? Do they scavenge to dirty oil out or do they just leave it in there?
    That looks like a lot of dirty oil thats left behind after you drain it.
  • Superglide2012
    Superglide2012
    Obviously it will damage the engine and reduce its life. Bad engine design or just another way of getting $$$ out of you?
  • Will67
    Will67
     there is always some one making money out of something, fair nuff the scavinger works but if you change your oil every 4-5k it shouldnt be an issue.
    just my 2 cents
  • Superglide2012
    Superglide2012
    Thanks for the replies. Will67 that looks like a 686 Smith. Is that right?
  • Superglide2012
    Superglide2012
    Yeah Will67 a S&W 686 is a 38/357 Magnum. Not many had the underlug on the bottom of the barrel. I had one with the adjustable front sight. The 586 was a blued finish and the 686 was stainless.
    Its since been rebarreled and modded to the max and its not mine. The mate bought it and did all the work.
    I have a Ruger Vaquero now as a revolver.
  • Superglide2012
    Superglide2012
    Very good. Did you get to have a shot of a machine gun?
  • AJ56
    AJ56
    Girls n Guns.....
  • Superglide2012
    Superglide2012
    Girls and Guns? You calling us girls?
