Online: Soapbox2627
scavenger oil system
  • The Ox
    The Ox
    Hi thinking about buying a scavenger total oil system, does anyone use one , and are they anygood thanks.
  • AJ56
    AJ56
    I bought one and yep not a bad bit of kit. Can be messy with the oil change and a bit of stuffing around but, and a bit wasteful as well but, you will be surprised about the amount of dirty oil that comes out. There is conflicting opinions about changes the old using this system, some say yay some say nay, What you are happy with in the end is the most important thing.
  • russ4570
    russ4570
    I have one and use it on my bike. When I showed the guys I ride with they all turned up a week later with a box of oil and some beer. I LIKE BEER.
    So if you like BEER buy one and tell your mates.  Free beer!!!
    Regards
  • philthy
    philthy
    Pity they don't make a scavenger system to suit Rockers
  • footfulla
    footfulla
    yes i use the scavenger on my ultra best thing i got real easy to use good clean oil  very happy with it
  • skin1312
    skin1312
    Hi where can I buy one from for a 08 soft tail standard I am in Townsville
    thanks Skin
  • The Ox
    The Ox
    Here's the link skin.www.roguechopper.com/
    Just highlight the link and right click and copy then right click in address bar and paste.
  • chrise1961
    chrise1961
    They work well, surprising how much dirty oil is otherwise left in your engine.
    Cheers,
  • ozymax
    ozymax
    Chris are you useing it on your 2011? and how many times would you think you have used it?
    I like the idea but am cautious about the potential for damage. Then again old oil mixed in would be doing any good either
  • Burnzi
    Burnzi
    Dealer in Oz?
  • markwoumla
    markwoumla
    The Savenger system has many freinds and does what it is designed to do.  Cost approx $100 - 120 .  Approx 1 - 1.5 lts of diry oil is left in engine after normal oil drain.  What I do is drain engine as normal, install drain plug,  add 2ltrs of new oil,  that means that there is approx 3 - 3.5 ltrs in engine.   Let bike idle for about 5 minutes,  then drain oil as normal.   Then fill with approx 2- 3 ltrs (as there is 1- 1.5 ltrs still in engine).  Now you have diluted the dirty oil by approx 50- 60% that we have been doing for years.  Yes you are wasting 1- 1.5 ltrs of oil, but you wast some with the Scavenger anyway.   Not perfect, but something simple I can do. Just my 2 cents worth.
  • russ4570
    russ4570
    No dealer in Auz, at least last time I checked.
    Yes they can be a little messy. Expect to spill oil and have paper laid out on the floor to catch. Immediately after I change the oil a full can of that $2 de greaser from super cheap cleans up all the spills on the bike and the floor.
    Like many have said I also like the idea of 100% oil change. Never hurts to treat your bike with a little TLC.
    Skin1312 , Mate I would help you out with a loan of the Scavenger but alas I am working out of Vic at the moment. Buy one and you won’t be sorry.
    Regards
  • philthy
    philthy
     The Scavenger won't fit/work on Rocker type oil systems.
  • wayco
    wayco
    I got this email from scavenger regarding rockers:
    If you have the room to pull the return line out the RC120 will work. On the
    Rocker c the seat height is low and there is not enough room to remove the oil
    line from the tank for most people. In my shop I have Scavenged Rocker c's but
    it is a little trying on my patience and most people can't do it. That is why
    I do not offer a Scavenger for the Rocker c.
    Thank you,
    Philip LaFleur
    Rogue Chopper
    Box 763
    N. Scituate, MA 02060
    866-877-6483
    Hope this helps,its all to do with the removal of the return line-
  • Ando
    Ando
    Make you own out of old oil filters
    I cut open an old filter, pulled out the guts and rewelded up
    cost nothing,
  • wayco
    wayco
    Quote ReplyAlert
    cost nothing,
    Hi ando ,
    your idea works on evo's but not twin cam-evos filter is on return line ,but twin cam filter is on feed,so if you do as you have suggested you will have no oil pressure- thats why you can't use the two allen bolt ports just near the filter & have to buy an adapter for a cooler.
    Cheers Wayco
  • Glider
    Glider
    Been using the scavenger for about 18 months, got the kit with both tourer and softail fittings, works great on both have  a nightrain  & sTREET GLIDE.
    This reall does make sense, as an engineer, I believe it it best to completey change the oil, you will have less build up of sludge over time
  • Jay-Dee
    Jay-Dee
    7 years ago
    Quoting wayco on 02 Jun 2012 11:25 PM
    Thank you,
    Philip LaFleur
    Rogue Chopper
    Box 763
    866-877-6483
    An old thread dig I know but I don't really see any point in starting a new one even though it's in product reviews.
    Armed with the info quoted previously posted by wayco, have any Breakout/Rocker owning members managed to successfully use a scavenger on their bike since then?
    Unfortunately I hadn't read this thread before I purchased one and Phil neglected to tell me it probably wouldn't work (or it would be a bitch to use) on a Breakout. I can't see how the oil return line will come fully out without some butchery or dropping the feed line so I would appreciate any feedback or experience you guys might be able to offer if there is any, many thanks in advance.
    Jason.
    7 years ago
    Thank you,
    Philip LaFleur
    Rogue Chopper
    Box 763
    866-877-6483
    Quoting Jay-Dee on 02 Jan 2019 12:08 PMedited: 02 Jan 2019 12:09 PM
    Jason.
    Jay-Dee , I have not seen or used this product.
    Just wondering if you had your softail shoot the oil tank cap out, after an oil change?
    Just puzzled to know why you would want one?
  • Jay-Dee
    Jay-Dee
    7 years ago
    I just thought it seemed like a good idea rather than leaving nearly a quarter of the engines dirty oil in the engine after an oil change. I'm sure many, many Harleys have survived just fine the regular way but it couldn't hurt.
