Online: Rextheute2022
Big bore upgrade
  • Roadkingdan
    Roadkingdan
    Hi guys I've got a 2003 roadking Twincam 88 75k done I'm doing the rings etc was think about Fitting a big bore kit why if got it pulled down Does any know if I need a tuner etc or what needs to Be done as well Dan
    Tuner - yes.
    If your doing rings/big bore, and at 75k you will need to check/replace your Cam tensioners, you may as well
    change the Cams as well.
    Is it down on compression or burning oil ?
  • Roadkingdan
    Roadkingdan
    Yes it was down on the rear cyl and a litle nosie so
    That why I'm doing some work
    I was going to to the tensioners and lifter why down
    It the turner something I can do my self or need to take to shop
  • Fr3d
    Fr3d
    Is it carby or efi? around the time of change over. maybe you dont need a tuner but a electronic ignition?
    bigbore to at least 95 would be good.
    You can do tuning yourself if you have some computer skills, and you may also find a fuel map that will be close enough.
    A Dyno tune will set you back around $400 + the cost of the tuner.
    Possibly worth the money if your not that sure.
    There are some "plug and play" tuners around that auto tune, but I don't have much experience with them.
    Have a look in the tuning section here.
  • Roadkingdan
    Roadkingdan
    Thanks
    Dan
  • MUZZ101
    MUZZ101
    I had mine done for a couple of grand and that included a hi flow filter. Made a heap of difference.
