Online: baldy1450
13 Degree rake
  • mootan
    mootan
    Just been reading about a 13 degree  Standard Kit          http://chopperworks.com.au/softail.html#front
    Just wonderin has anyone got one , they say the handling is just as good as a stock rake, sounds to good to be true, any thoughts.
  • Dan
    Dan
    "they" say lots of things...
  • mootan
    mootan
    yep thanks blueey, still might go for a frame , just cant decide just yet.
    thyanks
  • mootan
    mootan
    thanks Ozroder , yep the geometry would be out a bit. Thanks
  • redrider
    redrider
    don't forget the total distance your limited to including rake and fork lenght is 550mm from the centre of the neck to the front axle , you would have to come into that to still be legal
  • mootan
    mootan
    i can see a lot of problems with a custom frame redrider , have now been thinking mebe a wide arse end conversion kit if i can find one , maybe a 250mm tyre with a 5degree 2" front end , havnt had a chance to have a good look around , any suggestions appreciated,
    cheers.
  • mootan
    mootan
    yep, looks goood , havnt got any more piccy`s.
    thanks anyway
