Online: beaglebasher
vibration in sporty
  • sportsterdavo
    sportsterdavo
    have a 2009 sporty,has vibration at 140ks.
    tyres right pressure,belt adjustment ok.
    any  idea,s...
  • Toto_jp
    Toto_jp
    is it just @ speed or have you checked what RPM in other gears it at can be engine resonating thru frame (harmonics)
    Tony
  • terroristone
    terroristone
    start with checking that all your engine mounts and bolts are tight.
    T1
    have your wheels front & rear rebalance as most shops don't balance the rear ? or the weight's could have fallen off esp if they spoke wheels .
  • sportsterdavo
    sportsterdavo
    thanks will try all of that....
