Online: John.R
2012 Street Bob Standard Exhaust (Valve)
  • dangerousdave
    dangerousdave
     Hi,
    On the 2012 Street Bob, there is a valve part way down one of the exhaust pipes that closes when the throttle is applied.
    When at idle, it is open and the bike has a bit of noise to it.  When the throttle is applied, the exhaust is less noisy.
    Does anyone know whe this vale is here?
    Is it for EPA compliance (Noise) or is these so other mechanical reason?
    Thanks,
    Dave
  • Daggs
    Daggs
    search "harley active exhaust"
    Dealer opened mine all the time through computer , 2012 SuperGlide.
  • dangerousdave
    dangerousdave
    Did a search and discovered a zodiac trick box. Couldnt find where to get this or a similar item. The trick box sounds like to prevents fault codes and forces vale to default, open or closed via a selector switch. Nice option!
    Scouser, do you recall if the article spoke of the trick box?
    Anyone have this article.
  • nhb006
    nhb006
    All I did was cut it off the head pipe, cut the heat sheild the same length and put the muffler back on... Was easy as, there was enough adjustment on the bottom of my muffs to take up the 3 inches or so I cut off the pipe.
  • nhb006
    nhb006
    They can, and they will, but even open, its still quiet a large restriction...
  • Hesh
    Hesh
    I may have misheard, but I thought the valve was there for when you hit 6th gear. Apparently it went shut in 6th to give it a little more back pressure to allow a little more torque in top gear. Might have heard wrong but I was pretty sure I heard right.
    After a tune though mine has been disabled permanently as I don't need it anymore.
    Hesh
  • dangerousdave
    dangerousdave
    Hi Hesh, It may be a benefit when in 6th, but seems to be related to rpm's/throttle position in neurtal and all gears.
    Did you install slip ons? I believe the valve should be disabled when slip ons are used.
  • Hesh
    Hesh
    Me personally? No. When the slipons were installed by the stealer at time of purchase, they did not perform any changes to the bikes ECM.
    Only when I added a filter over 12mths later did the valve get disabled by the tuner.
    Hesh
  • Daggs
    Daggs
    i heard that the active exhaust and intake valves open at 3000rpms...
    I removed mine right from new so dont know for sure
  • MADOGA
    MADOGA
    I found the easy way was a bit of wire twisted to keep it open,
  • Ted
    Ted
    just installed v n h big shots, what do i do with the bloody cable now ?? fp3 tuner going in next week with vo2 air cleaner ...
  • Daggs
    Daggs
    Hide the cable or remove it totally, I removed the whole actuator.
