Online: Rextheute2022
1000 ironhead
  • brakelate
    brakelate
    hey guys ,i have been tinkering and slowly getting this old rocket sorted ,however no matter what i do i cant seem to get it to launch ,im fairly sure its just the accelerator pump ajustment on the s&s shorty ,as everything else is great , at an idle in neutral if i snap the throttle open it responds perfectly but sometimes in nuetral and almost everytime in gear it fails ,like it floods ,so i back of the throttle and roll it on slower and it goes like it should ,im just wondering if that ajustment is theat precise that im missing the spot ???
     looks like a 1979 motor in & early  1978 or early frame ?,  drag pipes do not like any baffles @ all + drag pipes like to run on the lean side of the fuel curve , look down the carb throat with a tourch & back the acc pump off so it only just squirts   a small amount  only  then jet carb down untill you have a small flat spot  then go up a size , but 1st  things 1st , make sure fuel system is very clean tank cock & all   , adjust tappets  , clean & service bobweights & set points gap  then set the timing  or if you have & electronic ign system  check with timing light @ 3,000 rpms + with the strike mark in the window  then jet carb last
  • Filthy
    Filthy
     Try this Brakelate :
    http://www.sscycle.com/carbquickguide/
    They are an easy Carb to tune but the old Iron Barrels are hard on them. The brass bushes for the butterfly flog out with the vibrations and then they can suck air and be a bitch to tune.
    Back in the day when you could get leaded fuel they were the easiest carb to tune based on the colour of your pipes. They had a micture screw which enabled you to liteally lean them out or richen them up with a thumbscrew then "read" the pipes after a ride to see if the mixture was OK. I believe Avgas will give a similar colour to the pipes but have never tried it myself. A sweet running Iron Barrel will produce lovely light grey pipes.
    Nice looking bike - good luck with it
    Philthy
     in the sixty's they were the corvette of motorcycles
  • brakelate
    brakelate
    yeah thanks men ,
    its a 77 matching no's,30thou over ,2"pipes that i made with small mesh baffles with fully tunable electronic ignition ,
    if i screw the accel pump right in ,it does the same thing ,"fails"
    ive built the bike and the engine ,done all the work myself ,,i can get it to lauch with revs but just not by opening the throttle fully from a standing start ,
    it hoots men ,it does the ton easy ,ive taken some time and effort (blown the top out of a couple pistons and a few other hiccups)to get it running as good as it does,
    maybe its just me ,trying to get blood out of a stone ,otherwise its a very small area on the agustment i cant find ,,like approximately how many turns out are we guessing it should be ?
