Online: beaglebasher
Detachable-Key Lock-Saddle Bag Brackets
  • Sparra
    Sparra
    Mine are almost the same but in black...Ghost Brackets...I can't think of the name of the mob I got them off but they are in WA...Work a treat...
    Cheers...Sparra
  • galbo950
    galbo950
     I've got the Edge brackets and saddlebags on my wideglide.  When the bags are empty they tend to rattle a bit, no dramas when they got a bit of weight in them.
  • Isaac
    Isaac
    I'm interested in something similar - any chance of closer piccies from Owners of detachable systems? I'm wondering how they look/how much docking bolt is left poking out when the bags aren't on.
  • Sparra
    Sparra
    If you do a google search for Ghost Brackets I am sure you will find plenty of pictures...
  • robert65
    robert65
    ghost brackets . WA company Kazz Mazz
  • Granox
    Granox
    Mine are very similar to those and are called easybrackets. I got them from Rollies in Brisbane. They work very well but if you are going to use them you need to have a solid back on your bags. I used a piece of aluminum sheet about 2mm thick on the inside of my bags.
