Repco pro lift.
  • moffycc
    moffycc
                  Cut and tuck ,weld some new plates and drill some holes refit rubbers and now perfect for the rk. before it was to wide and not deep enough.
  • 883n Harley Convert
    883n Harley Convert
    I've been using mine quite a bit lately and its brilliant!! Didn't actually think it would come in handy as often as it has!!
  • terroristone
    terroristone
    i also use mine to wash my bike, make;s cleaning the wheels so much easier!
     Great gadget hey. I bought one about 4 years ago for $270 from the local harley tuna, now you gettem for 140 bucks from repco huh? I shoulda waited and bought two! still does make it so much easier to clean the machine. Only drama i seem to have with mine is when lowering it, the locks either side keep on engaging even when you hold the locking bar down. Oh well, still a great gadget and good to store your bike on if your not gonna ride it for a while. Makes the suspension firmer for longer and stops flat spots on th tyres. Yeah right!  Still Can't wait for no 18!
