Online: beaglebasher
Mobile bike technician/electrician in Sydney
  • Kerjikey28
    Kerjikey28
    Hey guys
    Anyone recommend a good HD electrician/technician in Sydney?
    Was planning a nice morning ride today.
    Tried to start bike....absolutely nothing. No ignition light,
    no side lights, no nothing, dead as a Dodo ;-(
    I'd used bike a few days previously and was fine.
    I'm thinking there's possibly some electrical short but want a
    professional's opinion.
  • OzGlide
    OzGlide
    What year and model bike do you have ? Looks like a 06 dyna in your aviator.
    1 make sure run/kill switch is in run position.
    2 Make sure the battery terminals are tight because they can come lose overtime.
    3 check battery voltage
    4 check fuses
    5 check maxi fuse
    6 Has anyone done any work on the bike like changing to chrome switch blocks etc.
    Let us know how these check out.
  • Kerjikey28
    Kerjikey28
    Thanks OzGlide
    Gonna head back into garage and check all
    your suggestions.
    I'll let ya know.
    Yeh, it's a 2009 Dyna
  • OzGlide
    OzGlide
    Must have got her going and still out riding ?
     i do know a fellow,   what area are you @
  • Kerjikey28
    Kerjikey28
    Sorry gents,
    Tried all your suggestions and wish it was as simple as some suggested....still absolutely bugger all.
    Didn't get to ride so went for a drink instead!
    Only work done to it was by myself.
    Fitted V&H fuelpak myself a few months ago and in honesty I had to shoe-horn the cables and fuelpak under the seat.
    I'll try that first and let you all know.
    Cheers lads
  • HogBag
    HogBag
    Unplug the fuelpac and run the ECM with out the tuner. The fuelpac may have taken a dump.
  • Kerjikey28
    Kerjikey28
    Right,
    First opportunity to get out to garage this morning.
    Reverted ack to stock ECU, bi-passed Fuelpak...........still nothing.
    Checked all battery terminals, earth etc....all good.
    No pinched cables or exposed cables.
    Totally at a loss here.
    Does the factory alarm/immobiliser activate ignition system ie, battery light?
    just wondering if fob battery has expired and this is the problem?
    Bit of a longshot I'm thinking
  • Kerjikey28
    Kerjikey28
    Disconnected battery. Absolutely nothing from alarm.
    I'm assuming battery is completely buggered.
    I've heard of them failing completely like this but never experienced it myself.
    Next question :
    Best place for new battery?? :-(
  • Kerjikey28
    Kerjikey28
    As suspected, the battery had shit itself.
    $163 later and all good.
    Gained some valuable information re: immobiliser, maxi fuses, charging battery etc along the way ,
    So thanks lads
