Online: Stuart
10" mini apes wiring and cables 2012 iron
  • HD883
    HD883
    G'day, Just wondering if anyone knows of any solutions for cables and wiring when fitting 10" mini apes to an Iron883 (2012), the bars are woth nothing but the wiring and cables hit hard, I have been told that Sportster Low cables may work, has anyone tried this or has this setup on there bike or any other solutions would be greatly appreciated.
  • terroristone
    terroristone
    check out road6customs mate, they have kits and are well priced, if ya need fitting let me know. i did my 8" apes, and have just ordered a set of 14" apes with cables.
    T1
  • bronson7
    bronson7
    hey mate currently doing the same to my iron, looked into the burly brand ones off ebay but thought id check in a shop too.
    If your in adelaide K&M motorcycles is worth checking out, the bars are around $80 (standard HD 10" bars) and all the cables wires etc. $220.
    $300 for the lot roughly but thats fitting it all yourself. The reason i went this way is the ones off ebay could turn up and not be good quality where as the ones im having made up are all to Aust standard and i know they are quality..
    hope that helps a bit
  • 308bever
    308bever
    anybody got a picture of a custom sportster with 8`` mini apes on it, and 10`` mini apes too? thanks (((-;
  • 883n Harley Convert
    883n Harley Convert
    I've got a few with 14's, nothing smaller sorry mate. Google, YouTube and you'll find what ya after
  • 308bever
    308bever
    ok, thanks (((-;
  • 308bever
    308bever
    that looks good, but i am hoping to see them fitted to a custom, coz they have the high curved riser with speedo below, thanks (((-;
  • 308bever
    308bever
    so are the burly brand cable/brake kits good?
  • 308bever
    308bever
    wire colouring does not worry me, but, what`s up with the cable quality hmmm?
