Hi Guys
Have a 2010 Harley V-rod Muscle
Looking at putting on TAB pips along with TAB fuel manager
Would appreciate any feed back on experience with this combination.
Is the fuel manager easy to fit and set up as I know bugger all about this stuff and dont think I could handle one of the fuel manager systems that require a computer to set up
Looking for some thing simple that will do the job when the pipes and the air filter are changed
The other option is maybe a good workshop in the Melbourne metro area that specialiseing in these things,, Any suggestions
regards
Slick 88
Hi Slick
I would have a listen to Tabs before you buy them
for performance and sound, Vance & Hines have slip ons and sound awesome
I'm trying to sell (onbehalf of a mate ) a set of tabs that came off his nightrod - no interest
I wasnt impressed by the note and loudness (wasnt) of TABS
Personally I dont think you can go past a SERT screamin eagle race tuner or thunder max
any of the plug and play tuners are limited.
If you want something interesting look up SWD
http://www.sw-x.de/
these slip ons are around $340 delivered
and sound great
best of luck
Got the tabs on mine, sounds great, Have the screamin eagle super tuner and a hi flow air cleaner.
You'll need to get a dyno after you put all the pieces on to get maximum efficiency.
