Fuel Taps
  • Stewy
    Stewy
    If the tap has a vacuum line
    It will not let any fuel through unless the tap is under vacuum
    ie- with engine turning over (that is enough vacuum to open the tap) or engine running
    Make sure you have vacuum at the hose when you hit the starter button.
    Or take the hose of the manifold end, place hose in mouth and suck
    with the tap in the on position fuel should flow when sucking. And stop when you stop sucking.
    You will not get fuel in mouth
  • Stewy
    Stewy
    Is the vacuum hose ok  splits etc
    is it connected to the manifold properly
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    always use pingels on bikes i do or own but have seen ppl leave tap on an have cases fill with fuel mainly with s&s carbs only good thing bout standard taps is got a good filter into tank
  • Gnoo
    Gnoo
    Hey Z, make sure a wasp hasn't blocked 'm up with mud,lol
