Online: Soapbox2627
Few Oil Change Questions
  • Gloved1
    Gloved1
    2007 Softail Deluxe...I am about to do my first Oil Change on my Bike, and although have searched a fair bit still have a few simple questions.
    1: i am going to go Fully Synthetic, as i have heard that you can use the same oil in Motor, Drive, and Transmission. Is this correct?
    2: Going to Fully Synthetic from Mineral Based, i am curious about doing the motor oil change. It appears that you mainly just drain the Oil Tank and I was concerned about the remaining oil in the motor and pipes itself? will this mix with the synthetic or is there a process to fully remove all old oil?  or is there nothing to worry about
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    ok this is wat i do first drain oil outta tank then take filter off put plug back in drain from tank an fill tank to normal level an start bike ..let it run till the old oil stops comin out the inlet to where filter screws on .you will see the old oil by colour then itll start to pump new oil cleaner colour once you see the new oil stop motor an fit filter then top oil up in tank ..run bike again an check by feelin if ya got hot oil goin threw filter then clean up an ya done
    i keep a 2l milk bottle handy cut to slip under filter b4 ya take filter off also i keep oil container from oil change b4 on other bike i give a clean an cut the side out it will fit under ya bike so u can dump old oil into it an pour into a drum to store or pour around the fence line to stop weeds n grass growin
    forgot to mention i always run 50 weight in summer then in winter drop to a 20/50 in winter thick oil dont get threw the jurnals quik enough but goin to 20/50 it can but still has the viscosity of the 50 needed when the engine gets hot
    in summer a motor gets hotter quiker an i change every 4k seein as it looses viscosity quiker in the warmer months
    hey cookie ill call ya fri sometime after/if i can get to town floods everywhere here atm thought id use sons boat to get some smokes earlier lol
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    why not run bike theres enough oil in system to lube it for few seconds been doin it like that since 84 when first evos come out shovels bit different as filters in all different places seein they not come out standard on em
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    if memory serves correct dont the manual say not to turn motor over while plugs are out cause it can play havoc with electrics on the later models ???
  • solo
    solo
    I switched to Synthetic in my 07 heritage way back when I only had 60 thousand k's on it, I now have over 150 thousand k's and still going strong..I use it in all 3 hole's....make sure you change the oil filter when you put the oil in, and you really don't have to drain every drop out, just let it all drain.....
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    agree with hmmmmm i had a look in manual ill check n see wat they say bout comp check but i think ya gotta disconect loom from coil first
  • footfulla
    footfulla
    yes mate i have the scavenger also for my ultra best thing i ever got good clean oil every time
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    not yet been pickin up bikes to get to new owners but will when i get a bit time
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    from yank forum
    http://www.v-twinforum.com/forums/twin-cam-engine-mods/118149-how-perform-cold-compression-test.html
    check manual morrow
  • HogBag
    HogBag
    I ground my plugs with wire when doing a CCP test. These late model Harley's should not fire the plugs with no compression but better safe then sorry.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    manuals dont say shit bout comp tests but its only a manual as we all know the manufacturers arent always to dealers so some stuff is missed the twintech ignition says same about not turnin over engine while plugs are out few yrs back i done it on a 2002 dyna an the canksensor shit
  • BURTO
    BURTO
     Was always under the impression that grounding the plugs was to eliminate the possibility of igniting the air/fuel mixture that is being forced out the spark plug hole while winding the motor over. Even though the chances of a spark igniting the fuel at atmospheric press/temp are slim.
    I usually remove the leads from the coil, then cover the coil with a clean rag or whatever..........just in case!
    Like I said before, I have wound efi motors over, without grounding plugs/leads, hundreds of times, and havent seen an issue yet with electronics.
    Maybe just lucky!!..............but doubt it!!!!!!!
    Burto.
  • jmac
    jmac
    Bit confused and maybe a dumb question but .... drained the engine oil - drain plug and filter replaced. 2.5 Qts of Mobile 1 in as per manual. Dipstick shows full to the top mark cold when it should be only half way up the stick .. Am I right in thinking once the lines and new filter fill when the engine is run it will all settle in to the right level?
    Awesome forum. Got heaps of good info out of it.
    2008 FatBob
